Is it possible to zoom the interface?
nunf_arm
Postby nunf_arm » Wed Dec 06, 2017 11:00 pm
I want to zoom the interface.
AnvilHouse
Re: Is it possible to zoom the interface?
Postby AnvilHouse » Fri Dec 08, 2017 6:34 pm
Are you talking about in the interface editor, or zoom interface events...we need a little more info ;)
Image Image Image
https://www.patreon.com/Anvilhouse ...yes...I am on Patreon!
-The store is under construction-
All items are guaranteed to work with 001 ;)
nunf_arm
Postby nunf_arm » Fri Dec 08, 2017 8:15 pm
Zoom interface event.
AnvilHouse
Postby AnvilHouse » Sun Dec 10, 2017 11:04 pm
Due to how 001 handles the edge calculation zooming an interface doesnt work out too well, but in the field category you can resize and place each by themselves
You can however check your interface based on screen size using the resolution dropdown here (highlighted with the red box)
Image Image Image
