Exp for mmorpg
NinjaDog
Exp for mmorpg
Postby NinjaDog » Sun Dec 03, 2017 4:22 pm
hiya
i been trying to make an actor give exp when i have spoken to him but have failed to do so atm i keep getting errors any in sight on how to do this within mmo template be good plz
best regards
noeneto123
Re: Exp for mmorpg
Postby noeneto123 » Wed Dec 06, 2017 11:55 pm
To give exp through the network u might use the Send Experience event, it can be found in the network events section under Server>Player Management folder. Also, remember that this event should be used only with the server, not with the clients, I don't know how u want to use it but if the player triggers it, you will need a new network event. It's quite simple do that, in network events, click in the new button, name the new event as you wish, add a new parameter and name it as "NP_Amount", check the Number circle and uncheck "Server can send this to clients". Now you shall click in edit script, find the Add Experience custom event and use it, in the P Client ID parameter, write this: Main.RemoteClient and in the P Amount write: NP_Amount.
Your new event must be like this one:
Once it done, you're already to give exp to the player by using this event in the client
Re: Exp for mmorpg
Postby Mr.Numbers » Thu Dec 07, 2017 12:43 am
You do not need to create any networking messages. This is quite a simple task, first you need to create a "Dynamic Server Actor" which is described more here:
http://www.engine001.com/wiki/mmorpg#dynamic_server_actor
On the left side of the scripting where you put the "Server Script", you just use the "Add Experience" Custom Event. This is located under Custom Events > Server > Player Management
The parameter "P_Client_ID" should be set to:
Code: Select all
Actor("relate").Variable("Client_ID")
And the parameter "P_Amount" should be set to whatever you want to increase the EXP by.
