changing FPS DLC into 3rd person
joihnsonlee
Postby joihnsonlee » Fri Nov 03, 2017 5:39 am
may anyone please tell me how to change the FPS DLC into a 3rd person view?
AnvilHouse
Re: changing FPS DLC into 3rd person
Postby AnvilHouse » Mon Nov 06, 2017 1:55 am
pretty easy actually, it would just require a simple increase to the focus distance within the Camera=1 script shown below
you may have to also add a +16 at the end of the current Z of the pan camera calculation (just below the focus distance) so the camera is more above your desired player model
Image Image Image
https://www.patreon.com/Anvilhouse ...yes...I am on Patreon!
-The store is under construction-
All items are guaranteed to work with 001 ;)
