Actor Interface Render Distance
RamchuK_Ntertainment
Ultimate 001 Member
Postby RamchuK_Ntertainment » Sun Oct 15, 2017 5:56 am
It currently appears that actor interfaces disappear at a certain distance. Is there any way of modifying this?
Travesty: 3D Survival - WIP >>> Forum Topic
University of Washington (BABA)
-REGT- Ramchuk Entertainment Games Team
Strategy/Action/Adventure
Copyrighted©2008-2017
Re: Actor Interface Render Distance
Postby Mr.Numbers » Mon Oct 16, 2017 6:38 am
Does increasing the processing radius (In game settings) fix the issue?
Postby Mike » Mon Oct 16, 2017 8:52 am
Nah, it's pre-defined for performance reasons. I could add an interface distance option...?
Ultimate 001 Member
Postby RamchuK_Ntertainment » Mon Oct 16, 2017 1:56 pm
Mike wrote:Nah, it's pre-defined for performance reasons. I could add an interface distance option...?
I think that would be a lovely idea; it would create many new possibilities. :)
Postby Mike » Mon Oct 16, 2017 4:38 pm
I've put it in my short term to do as it will be fairly easy to throw in :) !
Ultimate 001 Member
Postby RamchuK_Ntertainment » Tue Oct 17, 2017 2:47 am
Can this be set per specific interface (preferred) or will you be adding a global option instead?
Postby Mike » Tue Mar 20, 2018 11:45 am
Good idea, I'll make it an interface option instead.
EDIT: I've added an "Actor Render Distance" option to the interface editor for next version :) !
Last bumped by Mike on Tue Mar 20, 2018 11:45 am.
