[Testers Needed] Action/RPG Template Pro+ (Updated June 29)
Re: [Testers Needed] Action/RPG Template Pro+
Postby Mr.Numbers » Mon Oct 05, 2015 12:40 pm
Yes, in fact it is :)
gerardred
Postby gerardred » Wed Oct 07, 2015 8:22 am
Everything become messed up when I created a playable character with any actor templates except "playable character" O_O
Blood sprite also didn't found (error message) when I killed an actor.
I also can't unequip an equipment except when I use "remove all"
Postby Mr.Numbers » Wed Oct 28, 2015 1:57 pm
This is the nature of the template. In order to do some things I didn't have much choice but require a set template for playable characters. I could force the variables needed on ALL templates, whats your thought on this?
Thanks for reporting this, its quite a quick simple fix since its because the scripting ID for the blood sprite was renamed. Fixed :)
Hmm... This one is quite a pain :P I'll see if I can come up with a simple solution.
EDIT: Won't be adding this, I'd have to redo a huge chunk of work for this to work unfortunately. After attempting to quickly hack it into my current setup, my entire screen was filled with scripting errors :P (Perhaps at a later time I'll re-write this interface so this works)
Thanks for testing out the template!
Danny
Postby Danny » Sat Nov 21, 2015 4:17 pm
I got a error with this template. I added a party member and then opened up the inventory went to "Party" and then highlighted the "Test Member" and then got errors.
Postby Mr.Numbers » Thu Dec 03, 2015 8:18 pm
That is because the actor template MUST be the "Party Members" template (Or whatever its called). I may just make it so all actors have those variables to prevent any errors like this from happening.
Postby Mike » Sat Dec 05, 2015 9:15 am
Or maybe check the template or something first, and produce a proper error with instructions. Could be easier. Either works :)
gerardred
Postby gerardred » Mon Dec 07, 2015 2:35 am
Will the problem still occur if the user created a new actor template ?
Postby Mr.Numbers » Wed Jun 29, 2016 1:07 am
http://puu.sh/pJSfq/4df5dfcaf8.jpg
Project revived!
Please check the first post for the latest version, all feedback is welcome!
gerardred
Re: [Testers Needed] Action/RPG Template Pro+ (Updated June
Postby gerardred » Wed Jun 29, 2016 6:33 am
Does the "unequip" bug has been fixed ?
Postby Mr.Numbers » Wed Jun 29, 2016 12:58 pm
Not a bug, but no it has not been fixed yet. I'll look a bit more into it today and see if I can possibly come up with something (Without having everything implode like last time)
