How to download resources.
Re: How to download resources.
Postby Mike » Fri Jul 16, 2010 12:00 pm
So what did you have to do differently?
will
Postby will » Tue Aug 03, 2010 4:55 pm
i cant download the resources at all :( it keeps saying that i have to have something to manage the files, this never happened before with ANY downloads.
Postby Zhuge » Tue Aug 03, 2010 4:56 pm
You're clicking on them, you need to import them into the program. ;)
First, you've got to click on the Manage and Import folder under the resource section in the program.
Then, drag them in and they should work fine. :)
PibbXTRA
Postby PibbXTRA » Tue Oct 05, 2010 10:15 pm
Zhuge wrote:First, you've got to click on the Manage and Import folder under the resource section in the program.Then, drag them in and they should work fine. :)
That's what I did, but it's not working. When I drag the file over the area, it has that circle with a line through it, indicating that I can't put it there. I tried it with a few different files and had the same results. I've imported resources before... Never had an issue. I noticed the site has changed, maybe that is the issue?
Postby Mike » Tue Oct 05, 2010 10:19 pm
Try browsing for the downloaded files instead.
PibbXTRA
Postby PibbXTRA » Tue Oct 05, 2010 10:39 pm
What do you mean? Browse what?
Postby Mike » Tue Oct 05, 2010 10:40 pm
There's a browse button at the bottom left corner of that screen. Try using that.
PibbXTRA
Postby PibbXTRA » Tue Oct 05, 2010 10:48 pm
I'm sorry, it seems I had an older version. Problem solved, thanks. :)
GirlofWind
Postby GirlofWind » Sun Nov 07, 2010 5:38 pm
what are the specific ways to get the resources onto a windows xp computer? Thats my type of computer. its slightly different setup, and its a bit newer setup. can someone help me with this?
~ Wait, I can fix it.....
Tabula Rasa
Postby Tabula Rasa » Sun Nov 07, 2010 6:50 pm
Mmmmm.... click n' drag?
