Trigger script when map is entered (triggered by actor)
vlastan
Postby vlastan » Sun Dec 03, 2017 3:37 pm
Hi! I need some help with a script.
I have an actor that must execute a script every time the players enters its map.
The "loaded" trigger works fine with non persistent maps, but i need the script to be triggered in persistent maps too, and when the map is already loaded that trigger won't work anymore.
Anyone has some tips?
Re: Trigger script when map is entered (triggered by actor)
Postby Mike » Mon Dec 04, 2017 9:59 am
I suggest using an "Actor Loop" and doing your scripting there.
vlastan
Postby vlastan » Mon Dec 04, 2017 11:05 am
Mike wrote:I suggest using an "Actor Loop" and doing your scripting there.
In the "player enters" trigger of the map?
