Collision detection for larger/resized actors
fma_lvr
Postby fma_lvr » Tue Nov 07, 2017 12:09 pm
I've been wondering if there's a simple way to properly fit collision boxes to a new model without essentially creating separate actors and sprite settings for each possibility. That is, I like the idea of having slight size variations for enemies, but it doesn't work very well if their collision detection won't match.
Re: Collision detection for larger/resized actors
Postby Mr.Numbers » Tue Nov 07, 2017 5:10 pm
Hmm, if you are using the "Change actor size" event, or using the percentage modifiers in the actor window the collision should properly resize (And does on my end). How are you resizing your enemies?
fma_lvr
Postby fma_lvr » Tue Nov 07, 2017 6:09 pm
Mr.Numbers wrote:Hmm, if you are using the "Change actor size" event, or using the percentage modifiers in the actor window the collision should properly resize (And does on my end). How are you resizing your enemies?
I'm using size% changes in the actor window I believe. I had it set to 200,200,200 and my character would basically walk through that. I actually have experienced this repeatedly and ended up doing this to a base 'slime', making it massive, and exploiting the lack of proper collision with an enlarged actor by having a sort of "swallowing" mechanic.
Essentially, I'm accustomed to this, but I haven't tried the 'change actor size' event. I suppose I could throw that into a 'change existence' and have it work immediately, as that's what I've done with random stat variations.
It sounds like it should be colliding properly, but it definitely isn't, at least not through size % window changes.
Postby Mr.Numbers » Tue Nov 07, 2017 8:53 pm
That's as close as I can get to the slime with the following actor setup from a default pro template project:
Just to confirm. Setting up an actor this way on your end will not stretch the collision correct? Just want to make sure there's not an option you are picking somewhere that is messing up the collision resizing before sending this off to Mike.
fma_lvr
Postby fma_lvr » Tue Nov 07, 2017 9:14 pm
Sorry Mr. Numbers, I made a mistake. In the non-slime cases, I was using user-created resources which actually had questionable collision boxes; I was only using some of these on large scales, so I expected that was the issue. For the Slime example, it turns out I had something else at work, involving the slime going invincible at times which allowed you to pass through it momentarily
On another note, I'm still not sure how you would make something effectively invincible while still being able to attack them and collide with them. I suppose that's a separate question, but it would make things easier.
(Yes, I know you can set its hp to 0 but I don't want to have to do that, say, in a boss fight)
Postby Mr.Numbers » Tue Nov 07, 2017 9:26 pm
You could alter their "Attacked" trigger, or temporarily set their "Defense" stat to be really high. Glad to hear it wasn't a bug but just an oversight!
