problems with mesh collision.
dragonnutds
Postby dragonnutds » Tue Mar 07, 2017 3:55 pm
i am having 2 issues with mesh collisions.
first is that it imports sideways, and not saving rotations. it imported sideways when it was first added, but a simple rotation edit in engine would fix that. now it keeps restoring default rotation on save.
and second is that it only seems to work sometimes... at first i thought it was just sketchup but i am using a new app now and its still wonky,
edit, why did i put this in technical support questions? it should have been in error reporting.... oh well
but ya, the "only seems to work sometimes" may be wrong... any problems that i was having may have to due with the fact that all collisions, mesh, actor, built in tile system, all of it, is having a error.
edit, nvm. the "collision error" was a user error, so ya, all wonkeyness is still here, unless my model has some nasty user error in it...
Reason: Automatically merged double post.
RamchuK_Ntertainment
Re: problems with mesh collision.
Postby RamchuK_Ntertainment » Sat Oct 21, 2017 3:53 am
I can confirm the above to being an issue. :(
Travesty: 3D Survival - WIP >>> Forum Topic
University of Washington (BABA)
-REGT- Ramchuk Entertainment Games Team
Strategy/Action/Adventure
Copyrighted©2008-2017
Postby Mike » Mon Oct 23, 2017 10:51 am
If anyone can send me a blank project containing a single sprite with this mesh issue in question, in addition to a link to the .dae file that is being used, I can definitely look into the issue :) !
EDIT: Thanks to AnvilHouse's bug report, I've fixed the following:
-Fixed rotation changes of collision from not being saved.
-Fixed imported mesh collisions from being rotated incorrectly.
-Fixed misplaced mesh collision when inserted.
